AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MAP5 Oracle Spatial advanced extension vs shp2sdo & geomedia
6 REPLIES 6
392 Views, 6 Replies
HEllo
We're testing the Advanced Oracle Extension for map5.
We're testing it for populating our basemaps (arcview SHP) into Oracle Spatial, and trying to use them in MAP5 and Geomedia.
1. when using the shp2sdo from Oracle, we can only use the data in Geomedia, because Map5 uses only data from Oracle Spatial via its own metadata use and definition.
2. so, if we first import the shp file into MAP5, define the feature table via the MAPOSEADMIN, and use the Advanced extension for exporting, then the data can't be used in Geomedia for a reason we cannot detect, although we 're checking all the related tables.
Question
1. Is map5 using the SDO somehow different as it should be used?
2. Has anyone used SDO data (created via map5) in other GIS softwares (as fe Geomedia)?
3. How can Existing SDO data (created via SHP2SDO) in map5 used via the advanced extension?
tx
Luc
6 REPLIES 6
Not a solution but a question?  Have you tried
creating Oracle views on the 'raw' table data that reflect the required formats
of the Map 5 AOE or geomedia?  There is a similar views thread in the other
Map 5 newsgroup.
 Crispin
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
HEllo
We're testing it
use and definition.
Question
used?
tx
Luc
Hi Luc
Both Geomedia and Map(and for that matter other systems) will want their own
fields to interpret the data and do things like colours etc. What I would
recommend is
Load the data with Map and look at the structure. Then load with Geomedia
and look at the structure. You have to make sure your geometry structures
are the same
MAke sure you are using the latest versions of Oracle (preferably 9, but
8.17 at least) and Geomedia. SHP2SDO will create the data in a readable
format in terms of geometry, but not in terms of other attributes that
Autocad needs
Johan Nel
Open Spatial Technologies
www.openspatial.com.au
"luc_vanlinden" wrote in message
news:f100f7d.-1@WebX.maYIadrTaRb...
HEllo
definition.
Question
Geomedia)?
advanced extension?
tx
Luc
Tx Johan for your reply...In the mean time I did some more research...Map adds to the geometry tables some additional fields as you mentioned...two of them are the ADMPBLOCKSCALE & ADMPNORMAL...
They both have as datatype SDO_POINT_TYPE (in the MDSYS schema)...
When dropping these columns, the data can be used within Geomedia...Why, I haven't found out yet...I'm also runnning a request at Interg.
My guess is that maybe Geomedia has a problem when there are more than one column of a datatype 'geometry'...
tx
Luc
Yes, Geomedia (and ArcSDE) do not like
SDO_POINT_TYPE data types.
Cheers,
David
Tx
tx
Luc
I've received the confirmation from Interg that Geomedia only support SDO_Geometry as datatype. It can not handle any another 'spatial' datatypes nor datatypes from subelements from SDO.
Also Geomedia can't handle Views (tx for the suggestion, Crispin).
Apparently SDO datatypes aren't supported in the context of 'Snapshots'...
and since map definitly can't miss it's ADMPBLOCKSCALE & ADMPNORMAL fields, I probably need tocreate two featrure tables: one for and via MAP, the other for Geomedia...great;-(
tx
Luc
After all, Geomedia does support VIEWS, although you need to adjust Geomedia's metadata manually when working just with Geomedia (not the Pro version). When using the Pro version Interg provides a small uitlity that does the work for you...
So, make a VIEW leaving the the fields out with datatype SDO_POINT_TYPE...Update all needed metadata for Geomedia...and things are ok!
”Boost
