AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
map displays mirrored
4 REPLIES 4
194 Views, 4 Replies
I have one map that I am using that displays mirrored. If I attach it in map it was working properly, but now it looks like it is mirrored even when I query it in vs. opening the file. Has anyone run into a similar problem? Any suggestions on what to try?
Thanks. in advance.
Joan Nickins
4 REPLIES 4
Joan,
could this be related to a user defined UCS or view in the source
drawing?
Marion Pietsch
WW Support & Services
Autodesk GIS Product Support
> Thanks. in advance.
> Joan Nickins
I have checked the ucs and it was set to bottom, I changed it to world but nothing happened. The view seems to be consistent with the other drawings, so it doesn't seem to be that. Thanks for your suggestions, do you have any other ideas. I could send you the file if that would help.
Thanks for any help.
Joan Nickins
Information Systems Analyst III
City of Walnut Creek
(925) 943-5899 ext. 132
nickins@ci.walnut-creek.ca.us
I checked again and you were right the UCS is set to be mirrored from the world ucs. How do I get back to the world ucs so that my map is not mirrored?
Thanks again.
Joan Nickins
Joan,
the world UCS has to 'mirrow' option. Please check if the coordinate
system symbol (the x/y arrows displayed in the lower left corner of the
drawing) show a little square at the origin (a W in former ACAD
versions). Then you're sure the UCS is set to world. If there's no
square, enter UCS at the command line and select/enter the option to get
back to the world UCS.
If you are in UCS world mode and the drawing is still mirrowed then do
the following:
1- Go into the Tools menu and select 'Named UCS' or enter _+ucsman at
the command line. On the 'Named UCS' tab all available UCSs are listed
and the current one is selected. Check what it said about the Current
UCS just above that list. It should be 'Top'.
If it's set to 'Bottom' or anything else, exit the dialog box and choose
View > 3D Views > Top. That should solve the problem.
2- If not, could your Map coordinate system settings cause this
behaviour, because you might use a projection that distorts the objects
so they look similar to mirrowed? To me that seems very unlikely,
though.
Marion Pietsch
> not mirrored?
> Thanks again.
> Joan Nickins
”Boost
