AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Digiting in AutoCAD Map 3d 2012
5 REPLIES 5
431 Views, 5 Replies
I would like to know how to begin to digitize a .jpg file. I have the 2D Drafting Workspace selected. Next, in the Map Drafting tab, do I insert an image with the Insert Image tool? I did this and a new window called Image Correlation came up asking for insertion points. Is this how I register or georectify the .jpg file.
Or something completely different needed? For example, do I need to convert the ..jpg file to a different type of file? I am digitizing a section map of drill holes/.
What I am looking for is the step-by-step process. Thanks.
5 REPLIES 5
antoniovinci
Forget it, and vectorize automatically with the free Wintopo...
parkr4st
in reply to: antoniovinci
does the .jpg have a world file?  could be .prj or .tfw extension. file name the same as the .jpg file
antoniovinci
in reply to: parkr4st
parkr4st wrote:
world file... could be .prj or .tfw extension
Worldfile belonging to a JPEG may only have .JGW extension, sir.
After vectorising that raster by means of Wintopo, you could _ALIGN the vector result according to a couple of GPS points, or an ortophoto loaded from a WMS server.
What does it mean to vectorize?
antoniovinci
It means automatically transforming raster graphics in vector lines, instead of manually digitizing point by point.
About georeferencing a bitmap, it's not a good idea in my opinion: you'd better use Wintopo, then _ALIGN the vectors on the Earth as advised above.
Before saving the aligned drawing, don't forget to issue the correct CRS with _ADESETCRDSYS command.
”Boost
