AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Connect to PostgreSQL
4 REPLIES 4
1731 Views, 4 Replies
Can the Map3D connect to PostgreSQL database? I saw the document said it can be connect db have Oracle, SQL Server, ArcSDE or MySQL db. How about the PostgreSQL?
Thks
4 REPLIES 4
cgenovese
Any update to this with AutoCAD Map 3D 2012?
Murph_Map
in reply to: cgenovese
Hi!
Would like to confirm the 2014 (Map 3D, AIMS) can work with PostGIS 2.0.3? I found I cannot create a data store in Map 3D 2014! 🙂
Eric
You should be able to connect to a PostGIS 2.0.x data store, just not be able to create one with the FDO provider in 2014.
Reference: I got MapGuide to work with PostGIS 2.0.x and pgRouting using this same FDO provider
http://themapguyde.blogspot.com.au/2013/04/mapguide-and-pgrouting-shortest-path.html
- Jackie
”Boost
