AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD MAP and GIS interface
6 REPLIES 6
870 Views, 6 Replies
I have recently added the plug-in required for Map3d to use the aerials from Arc Map. There is a coordinate system setup which is easy to follow, but I haven't any idea how to set up the GIS overlay, and have contacted our GIS team.  They may not know either, because the plugin was news to them.  Does anyone know how to set up AutoCAD to use GIS overlay?
6 REPLIES 6
parkr4st
What version of Map3D and could you supply a link to the plug-in?
further on you mention Autocad.  do mean Map3D of vanilla autocad?
dave
braudpat
Hello
+1 with Dave
1) You have a "vanilla" AutoCAD  OR  an AutoCAD MAP 3D ?
2) Which release of ACAD or MAP : 2014 / 2013 / 2012 / 2011 / etc ...
3) The Plugin : which one ?
- The Bingmaps plugin of any ACAD 2014 ?
- The Bingmaps / Google Earth plugin of Plexearth ?
- The OLD Google Earth Plugin of Autodesk for ACAD/MAP/etc version 2012/2011/2010 ?
- An OTHER Plugin ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
in reply to: parkr4st
Hi, I have installed the plug-in, Arc GIS interface, 3D Map in my 64 bit system.
Thank you,
Autumn Murr
Sr. Designer
Chevron WCC Projects, SJVBU
9525 Camino Media Drive: Building C #1058
Bakersfield, California 93311
Direct: (661)412-6006
Cell: (661)437-0347
[cid:image001.png@01CF26E8.98D619B0]
in reply to: braudpat
Requiero del plug in para exportar DWG to GE del 2011 donde puedo conseguirlo.
I need the plug in to sport DWG to GE 2011 where can i download it?
gn.gr.jzereceda@gmail.com
Gary_Braun
It sounds like you are using "ArcGIS for AutoCAD". If that's not the case then the rest of this won't apply.
I'm assuming you can add an ESRI basemap without any problem but are not sure how to add your own GIS data. Click on Add Service, then at the bottom of the pop-up click on New Server Connection and add the provider details for your ArcGIS Server services. Typically this will look something like http://<servername>:<port>/arcgis/services.
Once that's set up then that server will show up in the list when you click the Add Service button. Select that server and you will get another window listing all of your published services, simply pick the one you want and add it to your drawing.
”Boost
