Hi All,
AutoCAD M3D fails to insert an image (Raster) for a large area (Approximately 12774.594 km), while everything is fine for a smaller one (Approximately 5136.014 km).Attached
What might the issue here? Does anyone face this issue before?
Best,
Rawan
Hi Rawan,
It seems that you use a intelligent Format like JPeg200, Ecw or MrSid.
If not, please try to convert it to one of These. They work with a density pyramid,
and Map Needs not so much Memory for the Image.
Here are some more proposals to solve your Problem:
Thorsten Scheel
Dear Scheel,
Thank you for your answer.
Kindly note the following points:
I will try your suggestions and see if that works with me.
Best,
Rawan
>> I use AutoCad M3D without service pack.
That should be changed first, make your product current.
>> My images without cache
AutoCAD Map 3D does caching, if you want it or not, so make the cache folder clean
As one image is ok and the other Tiff is it not ... have you tried to open the larger Tiff-file in an image viewer? (just to make sure the file is valid!)
As it is the larger image that failes: look to the task-manager and while loading the image what is the memory AutoCAD Map 3D is using and how much memory is built in your system?
What you also can try to change: use command _MAPCONNECT instead of _MAPIINSERT and see if your can load the image then.
HTH, - alfred -
Dear Alfred,
Thank you for your answer,
I download the service pack 3 and use it in my AutoCAD M3D but that didn’t solve my issue, also I clear the cache for images but with no effect. see below
the following screenshot shows the size of that image.
Also, I tried to use map connect command instead off map insert command but I have the following error also.
despite the fact that the same image can be added to ArcGIS, M3D fails to inset it . see below
so, what might the problem here?
Best,
Rawan
in the screenshot it looks like you are loading the image from a NAS drive ... what about first copying the file to your local drive C: and try to load it from that location?
- alfred -
Dear Alfred,
I tired what you suggest but with no result, see below.
What might be the issue here?
Best,
Rawan
rawanssaleh wrote:W
I bet you're facing a compression issue, sir.
Extract the worldfile from the Geotiff, in Irfanview decrease the colour depth to 8 bit, save as LZW compressed, then load it in Autocad: what happens?
Dear Antonio,
Thanks for your reply, actually I did something near to what you suggest and that’s work fine with me.
I used “Export Raster to other format” option in ArcMap and export the tiff file to JPG file, then the AutoCAD Map able to insert the image.
Best,
Rawan
Hi Rawan,
please remeber my proposal trying to convert theiImage and try loading again.
Weeks ago I have also problems with a image till I convert it to a different format.
But my effect was, that I can't see the Image after successfull loading.
That was the reason I give you the tip to convert not as a solution but as a proposal.
Good to hear that your Problem is now solved.
Thorsten Scheel
Dear Scheel,
Many thanks for your answer.
Actually I tried to export image with other format from mosaic but t doesn’t work, so I export it as a tiff then I used “Export Raster to other format” option in ArcMap to convert it and that works fine.
Best,
Rawan
