AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Autodesk Map OData Problem
1 REPLY 1
542 Views, 1 Reply
Tables tables = Autodesk.Gis.Map.HostMapApplicationServices.Application.ActiveProject.ODTables;
Autodesk.Gis.Map.ObjectData.Table table = tables[TblName];
Records records = table.GetObjectTableRecords(0, id, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead, false);
if (records.Count == 0)
Record record = Record.Create();
table.InitRecord(record);
table.AddRecord(record, id);
Why the following is error:Records records = table.GetObjectTableRecords(0, id, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead, false);
1 REPLY 1
Daniel.Du
Have you ever checked this blog?
http://adndevblog.typepad.com/infrastructure/2012/05/adding-object-data-records-to-entity-using-map-...
Does it help?
Daniel Du
Developer Technical Services
Autodesk Developer Network
