Show only
Search instead for
Repeat step 2 for as many related block definitions
as you want to make.
Save the drawing using a name appropriate for a
library drawing.
These blocks can be inserted into any drawing using
DesignCenter (ADCENTER).
basically just make a bunch of blocks in a drawing file
and then access it through the design center. to add more just open the
file and create or insert more that you would like to use
