I've always believed that Autocad (including LT) can open a file saved in any previous version. That's been my experience and why I save files as a previous version when sending files to consultants. Is this not true for LT2007?
Solved by lostagain. Go to Solution.
Solved by pendean. Go to Solution.
Is the program saving the file AutoCAD (full) or some other vertical?
Only reason I can think is a Revit file or something similar not wanting to open in LT.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I am saving from regular Autocad 2011 to 2004. The recipient is using LT2007 and can' t open the file. The problem isn't that LT2007 can't read a standard Autocad 2004 version file - right? So I can narrow down what exactly is the problem. Thanks.
Proxy objects maybe?
Any warnings pop up from the LT 2007 user when they try to open the file?
Audited or Recovered the drawing prior to Saving?
Your right that it does not make sense.
I am in LT 2012 but post your file if you can so I can give it a go. Maybe someone here with LT 2007 will try too.
All I'm asking at this point is whether my long held belief is correct that Autocad (LT or regular) can open any file saved in a previous version. It's not stated in the HELP, but it's been my experience and I posted here for confirmation.
I appreciate the tips on additional troubleshooting, but I'm not at that point yet.
