Bill, the recommendation probably should be to run a Custom install, and
de-select the Volo View Express installation, since it does seem to cause
problems for all 2002 products if installed at the same time as the AutoCAD
product.
Volo View Express can easily be installed separately from the CD.
Dean Saadallah
www.pendean.com
"Bill Gilk (Autodesk Support)" wrote in message
news:3BAFB63B.7C70948D@autodesk.com...
> Graham,
> Are you sure that it just stalls out? It may be that the Volo View
Express
> wizard (win installer) is setting behind the end of the LT 2002 install.
Try
> reinstalling and if it just sets there minimize the LT install window and
see if
> there is another install window for Volo View Express.
> Bill Gilk
> PSG Product Support, Americas
> WW Support & Services, Autodesk
> Discussion Q&A: http://www.autodesk.com/discussion
> Dean Saadallah wrote:
> > Restart your PC, turn off all running background applications (lower
right
> > corner of your Windows screen, your Windows System Tray, right click and
> > turn off everything), double click on My Computer, delete everything in
the
> > Windows>Temp folder, Delete all LT2002 reference folders under Program
Files
> > folder, do a system FIND and delete every reference to LT2002.
right
> > turn off everything), start the installation again. See if all that
helps.
> > Dean Saadallah
> > www.pendean.com
> > "Graham O'Neill" wrote in message
> > news:171D74561C51FB6A014F528AD7B4E5D9@in.WebX.maYIadrTaRb...
> > > I am trying to install Autocad 2002lt on my windows 98 PC and it gets
to
> > the
> > > end and just sits there and when I eventually quit the install and
tried
> > it
> > > again it comes up with resume and sits there again doing nothing. If I
> > click
> > > on the shortcut I get the following error: INTERNAL ERROR: Sequence
error
> > > reading initial allocation list.
> > > If I try to uninstall it it just goes back to resume installation.
> > > Any ideas?
> > > Graham
