I work at an arena in Austin, TX and am looking for a way to create a low res pdf version (printable) of our arena layouts (bowl seating area, floor, etc). Currently I am creating 3MB to 5MB pdfs and when we send to third parties it takes forever for them to flatten and print. To curb this issue currently I use the pdf to take a sreen shot, create a picture file, paste and fit to a word doc then convert back to pdf... there has to be an easier way to do this... any insight?
Looking for a way ideally to create low res pdfs straight from AutoCAD 2010 LT.
Thanks in advance for your help!
To stop "flattening", you need to stop adding layers information to your PDF: turn off INCLUDE LAYER INFORMATION in the DWG to PDF Driver (you get to edit with PLOTTERMANAGER command, double-clicking on the PDF driver, Device Settings Tab>Custom properties...).
You also turn off LINES MERGE option in Merge Controls for teh same PC3 file (same location as above, except Merge Controls instead of Custom properties). This also adds layers information to PDF files.
Does LT 2010 have DWG to PDF. pc3?
If so open your Plot manager, set printer to DWG to PDF, Properties,Device and Doc Settings tab, Custom Properties, Custom Properties, and change the Gradients.
Same should be able to be done with whatever PDF driver you are using.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks for the insight. I've lowered the gradient levels as low as I can, taken off the layering information, etc. and am still getting tons of flattening (takes several minutes to print). Any other ideas?
Did you address Line Merge?
You may need to give up on gradient hatches, they are layers too, regardless of settings.
