I am having trouble linking an Excel table. The attached screen shots show what I am doing:
I open Data Link Manager
Capture4 - selecting linked table
Capture5 - opened selected Excel file - note that the File References window shows the new link as unreferenced but it appears correctly in the preview pane. I also tried linking a named range & specified range with the same result - the preview is correct but the reference is tagged as "unreferenced". I also tried all combinations of cell contents & formatting options - same result
Capture6 - everything looks OK in Data Link Manager but link shows as "unreferenced"
When I click OK in Data Link Manager nothing appears on my drawing & link still shows as "unreferenced"
I have used this table linking method many times in the past & it has worked but now it has stopped working. Am I missing something obvious? Is there some setting that has to be changed?
_xref
_DATALINK
clicked on "create a new excel data link"
entered "1" as "name"
clicked "browse for file" ...
selected "test.xls"
clicked "OK" - "file references" dialog box shows new link "1" as unreferenced & nothing appears on the drawing.
I figured out my mistake. I have to start with the _table command then the link I create is loaded.
Problem solved
Colleagues, I noticed that the connection with Excel, lying on level 2 investments are not updated. Need to open a new link, update links with Excel (a very long time about 5 seconds on each drawing, i.e. about 1 sec on each link!), Close external links. Update external links in the main drawing. If you do 2 projects at the same time, the external link to them is the same, but the signature on it is different for each project. Can you imagine that happening?
Hey, at Autodesk! In the yard in 2014, wake up!
