Changing the units is not a correct way although it is more convenient. It only changes the units you view.
You may experience problem if you export the drawings into other formats, such as: dxf.
Besides of scaling the whole drawing, you may also copy all the entities into a new drawing which use metric system as template.
However, you may need to manual copy some of the unused blocks and layers to the new drawings.
Good luck.
