I am having an issue with line types. I have about a dozen lines types that are coming up in my drawings, they are not being used by a single layer or object in the entire file, but they cannot be purged from the file, nor deleted by the Linetype Manager. How can I remove these line types from either of the files that they are appear in. They have infected my template files. TO make matter worse I cannot copy ANYTHING from the infected files into a new drawing because these linetypes will be carried into the new drawing. For some dumb reason I cannot attach a .dwg file to this message to provide an example.
Welcome to the Autodesk Forums!
Yes it is an issue attaching DWG files; has been for a while. Try to Zip it and then post.
Have you tried QSELECT, Linetype and then ERASE?
How about WBLOCK to a new file?
Did you download any vertical or 3D content like Blocks or Manufacturer drawings?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I had the same issue for 12 LT. The only way i was able to get rid of it was to re-install. I had to wipe my autodesk directory then fresh install.
