How can I get annotative dimensions to appear in viewports with different scales with text etc. at the same size?
Solved by heinsite. Go to Solution.
Solved by pendean. Go to Solution.
Assuming your text STYLES and DIMSTYLES are oth annotative, and your DIMSTYLE is using your annotative text STYLE, simply changing the viewport's scale will do it. If not you got something set incorrectly and you need to post a sample DWG file for others to help further.
Many thanks for your response. I'm sure that I am missing something here. Please see attached file. Square is 500 x 500 units and there are 2 annotative dimensions 1:5 on the top and 1:10 at the bottom of the square.
Viewport scales are set to 1:5 and 1:10.
Hope you can help.
I got the same results with your file. But I made it work once I did the following:
Deleted the viewports and dimensions in model space;
Reset the ANNOAUTOSCALE system variable to 0 (it was set to -4);
Redo the dimensions at 1:5 and 1:10 in model space; and,
Rebuild the viewports.
Simply resetting the system variable didn't do it by itself for some reason. I'm sure someone else here will be able to explain why.
BTW, I also created a new DIMSTYLE with a text height of 5. It probably didn't make any difference in making things appear when they should have, but it did help when it came to seeing the text in the dimensions.
Dave.
Your DIMSTYLE is annotative, but the text style it uses is not.
Your active text style is not annotative, and all your text styles have a zero height (in annotative, you must provide a Paper Text height).
So all your dimensions are doing are following your hardcoded unchangeable settings, just like you set them.
Here is your file, fixed, without deleting anything. It was only following what you set it to do.
>>> (in annotative, you must provide a Paper Text height) <<<
That's a golden nugget of info.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I don't believe your revised file completely fixes the problem. Everything still shows in both viewports (1:5 & 1:10) in paperspace. And the dimensions continue to show even after modifying their properties and removing unwanted annotation scales.
So you don't want the dimensions to appear? Freeze their layer inside each viewport separately from modelspace layer settings. Your pick: LAYER or VPLAYER commands.
Dean, you may have lost sight of the OP's original problem. He was having problems getting annotative dimensions to display in two differently scaled viewports. It appears to have been solved now, but it's still not quite clear (to me at least) what was happening.
In your file I got it to work but it still required (1) removing and replacing the 1:5 and 1:10 viewports on his layout tab, and (2) going back to model space and verifying that each dimension was only associated to the annotative scale it was supposed to be associated with. In your file both dimensions were associated with 1:1, 1:5 and 1:10. That's why they showed up in both viewports. Simply fixing the associative properties wasn't enough... the viewports still needed to be redone. Once that was fixed it all worked the way it should, and the way (I think) the OP was expecting.
Dave.
... a btw, it's not necessary as I noted earlier to reset the AUTOANNOSCALE variable after all. It can stay at the -4 default value and things will still work.
my bad.
Dave.
Annotative scaling is a little tricky to learn at first, but once you get how all the settings work together you'll be fine. It's easy to end up with everything associated with all the scales you use too if you're not careful, and that was what I looked for to start in your drawing. But it didn't quite solve the issue for some reason - still not quite sure why.
But when I use annotative scaling I'll always check first to see what scale I'm going to be using in paperspace before doing anything else. Then I'll go into model space and make sure that scale is set before doing anything. The other thing I'll check is that the "Show annotation objects for the current scale only" icon is ON, and that the "Manually add scale to annotative objects" icon is OFF. From there I never have problems.
Dean suggested, and I strongly agree, that you need to create annotative text, dimensioning, and leader styles with your paper space text heights defined for this to really work the way you expect. For your file I made a P3 DIM style and bumped the text ht up to 5 units and also increased the arrows (also to 5) so I could see more clearly what was going on. But it did work... both viewports displayed the annotative objects they were supposed to properly with the text and arrows the same size in both.
Keep experimenting with this. Once you get it you can move on to the next topic. We all go thru this.
Dave.
