AutoCAD LT Forum
XREF will not display in new drawing
7 REPLIES 7
Message 1 of 8
552 Views, 7 Replies
Hopefully this is something simple. I have a DWG drawing that won't display in model space when I XREF it in. I've checked the layers and all of that XREF drawings layers are listed, turned on and thawed. I'm trying to XREF this into a new drawing using the aclt template. Does anyone know what may be causing this not to display? I've attached the file so maybe that will help. Thanks in advance for your help with this.
Monty Robison
7 REPLIES 7
Message 2 of 8
Zoom>Extents perhaps.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 8
Hi Dean,
Thanks for the reply. I've tried zoom extents, zoom all, etc. Have you looked at the file? Any other suggestions or thoughts? It's strange because the drawing opens just fine.
Monty Robison
P.S. - I just discovered that when I open the drawing the model space is empty. Only the paper space displays. Edited by: montyrobison on Nov 3, 2009 5:55 AM
Message 4 of 8
The drawing you posted has no XREF in it.
Message 5 of 8
Did you look at your posted file? Nothing in it except a titleblock in
paperspace.
Is that your issue, you inserted your titleblock in paperspace OVER the
layout and not inside it?
Dean Saadallah
Message 6 of 8
I think what the OP ment is that's the file he is xref'ing. He needs to place the titleblock lines and text into model space if he wants to xref it into another drawing. Items in paperspace are not displayed when a drawing is xref'ed.
Message 7 of 8
That must be it, thanks.
You cannot XREF layout content, only modelspace content.
Dean Saadallah
Message 8 of 8
kcsalefty,
Thanks for your reply. You pretty much nailed it. I'm not sure how, but when I saved the file as a DWG there was nothing in the model space. I'm trying to remember what I did. Anyway, I was able to copy the contents of paper space and paste them into model space. I then saved the drawing as a DWG, closed the drawing and re-opened it. Now it opens in model space and I can use it as an xref in a new drawing. Thanks again!
Monty Robison
”Boost
