AutoCAD LT Forum
Where to set the Fade Control of Locked Layers
10 REPLIES 10
Message 1 of 11
octavio2
42187 Views, 10 Replies
Can you advise where is the setting to change the Fade Control when you lock a layer?
(It is not the same as the Fade Control of the External References in the Display tag of the Options dialog.  I know that one and I am awere of this one.)
The one that I want to know is of the locked layers.  When I lock a layer, the objects in the layer fade.
Thanks in advance.
10 REPLIES 10
Message 2 of 11
sthompson1021
in reply to: octavio2
Hi, the command is LAYLOCKFADECTL.
Message 3 of 11
octavio2
Thanks.
Is this setting not available also somewhere easy to find or to set location like in the Options dialog or in the Menu bar or in the Ribbon?
We use AutoCAD Lite 2013.
Message 4 of 11
sthompson1021
If it is, I haven't found it. It's one of those commands that I only use when I update from one year to the next so I have it written down on my cheat sheetSmiley Wink
Message 5 of 11
sthompson1021
It is on the RibbonSmiley Surprised. I use classic so I never looked for it there.
Message 6 of 11
octavio2
Thanks for your help, sthompsom.
Message 7 of 11
in reply to: sthompson1021
Your post was five years ago -- and it's still helping people.
Much appreciated.
Smiley Happy
Message 8 of 11
 type LAYER, on the top right corner click on the settings button, under isolate layer settings, turn on LOCK AND FADE set from 1-100%
Message 9 of 11
in reply to: devillord1990
i want change only  one layer colour how is it ? other layer make dark and one lock layer is brightness high specially text
Message 10 of 11
pendean
LAYER command is used to change a layer's color: you can adjust or turn off locked layer fading levels with LAYLOCKFADECTL variable as discussed in HELP and here https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Core/files/GUID-753F2A76-E248-483F-9F55-CCF613B12C31-htm.html
Message 11 of 11
doanthaihung
Layer Settings -> Isolate Layer Settings -> Off -> OK
”Boost
