AutoCAD LT Forum
Un-grouping an array
5 REPLIES 5
30927 Views, 5 Replies
So I have created an array to layout my drawing of some blocks that I created. I took each array and copied it (not as an array) Now I want to drill down and do a count of the blocks that are in my drawing.
How can I "explode" the arrays so that I no longer have any 'arrays' but now just my blocks?
basiclly I am building large arrays and need to count items after they are spaced out. what is the best way to do this if not able to explode or exit the arrays?
Josh
Tags (3)
5 REPLIES 5
pendean
I take it you did not actually try EXPLODE command yet?
PROPERTIES command gives you row/columns counts if you select an ARRAY too, if you want to avoid exploding.
Emmanuel.Delay
in reply to: pendean
Thanks.
Don't you guys think it's a bit strange you need the seperate command EXPLODE;
while X (when the array is selected) doesn't work?
Any justification for this?
pendean
in reply to: Emmanuel.Delay
Log into your subscription page and ask Autodesk: we are just end users like you over here.
Emmanuel.Delay
By the way, I was wrong. My problem was the 1-letter aliases; X is not automatically linked to explode; now X stands for xline. That's a different problem
pendean
You can change that behavior easily to suit your exact needs: X here for example is XPLODE command (that's right, no E) and XL is XLINE 🙂
”Boost
