I created a table and used formulas to calculate results within the cells. The calc's are correct but an annoying gray text background mask displays with the results.
I tried properties dialog, text dialog, text editor, table editor, and can't make the mask go away. Model,Paperspace, plotting and it still appears?
Solved by steven-g. Go to Solution.
fielddisplay to "0" worked great, thanks for the tip! And sure its tough to pick out cells with formulas but you can read the tables after plotting.
Fielddisplay (not field display) is a system variable,
so type in
FIELDDISPLAY
press [enter]
press[F1] to read the help
type in 0 or 1, follow by [enter]
to change the current setting
BUT: No background forces trouble, because you can not see that a Text or part of them are field values.
Or at the command line type OPTIONS and untick the box ringed in the image below
Howard Walker
