I am trying to publish a number of different layout pages (all 11x17) from different drawings into a single pdf. I want to use the publish function to do this, but for some reason it keeps shifting my drawing down slightly. I don't seem to have this problem though if I create a pdf for each page directly using the plot function.
Does anyone have any idea why the publish option may be shifting my views while the plot function isn't? It would save me a lot of time to use the publish command if possible.
Thank you,
Solved by pendean. Go to Solution.
It likely depends on the page setup and plot styles as mentioned before. Each sheet should be checked to verify they are setup the exact same.
I used to see this when one or two sheets had a slightly different style.
How are you selecting the page setup in publish?
When using the publish function should I be selecting the "plotter named in page setup" or the "pdf" option? I've attached a picture of my publish set up to try and help.
Also when setting up a layout using the page setup manager, would you select going with the DWG To PDF.pc3 for the printer/plotter or go with the driver for the printer that I have here in the office?
Thank you all
