AutoCAD LT Forum
PDF Export : Fatal Error
3 REPLIES 3
987 Views, 3 Replies
Everytime I try to export my dwg to a pdf file I receive the mesage "Fatal error: unhandled c0000417h at 73800468h" and AutoCAD 2013 LT closes.  I need to export to share files.  Any Ideas on what may be causing this?
3 REPLIES 3
pendean
Try PLOT command to create the PDFs, see of that works. PUBLISH command if you need to do this for many layouts at once.
in reply to: pendean
Thank You for the suggestion but it will not create an Adobe PDF file.  It does not crash with a Fatal error but will not create a .pdf file I can open with Adobe Acrobat.  It does sometimes create a .plt file and other times returns with an error message that it can not create file.  I did this regularly with ease on AutoCAD 2005 but 2013 is less useful and freindly?!
I am not sure if there is a setting in the plot and publish configuration or something else.
Thank You!
Tracy
DTSDesignStudio
pendean
Sounds like a possible destination problem: try creating the PDFs on your PC (like your desktop). Also confirm you are using the DWG TO PDF.PC3 driver to create the PDFs (that's what exporting does).
”Boost
