AutoCAD LT Forum
New versions
2 REPLIES 2
158 Views, 2 Replies
New versions
I am about to upgrade from LT 97. Before I spend the money, I need to know if there is a version newer than 2002 that is about to be released. If I purchase LT 2002 and a newer version is released within 6 months will I get a free upgrade to the newer version?
2 REPLIES 2
No one knows when the next version will be out: Autodesk does not
pre-announce.
Besides, at 5-versions back, you will have your hands full
figuring out LT2002, so go for it.
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"loganwhite" wrote in message
news:f11c8cb.-1@WebX.maYIadrTaRb...
version?
There was 95, 97, 98, 2000, 2000i, 2002.
Since 2000i should have been 2001, they are probably due to skip a
year. But skipping a year does not increase revenue... So I really
don't know.
Finding a good reason to upgrade is the problem I have. I can do what I
need to do with LT 98 so why get 200x? I bought LT 2000 when it first
came out but quickly found that was easier to continue using 98. I use
2000 mostly as a file filter to turn 2000 files into LT 98 files.
I guess if you need to read 2000 DWG files you should go for it. If you
have no other compelling reason, stick with LT 97 and you may be able to
save the cost of an upgrade when LT 2003 or LT XP comes out.
Len Rafuse
Vision Engineering
”Boost
