AutoCAD LT Forum
Insert default inches
5 REPLIES 5
154 Views, 5 Replies
Why do some blocks insert 25.4x out of scale?
Everything was fine a few months ago.
Ddunits set to "mm"
5 REPLIES 5
:)) UNITS sets your current file, now you need to set your inserts:
INSUNITS is a good place to start, also explore other system variables
that start with INS in Help.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Very good, the 3d design prog that I use is the culprit. Which explains why the prob is not consistant.
Can you also help me find the hidden garrot, shoe phone and derringer?
Is it a 'metric' 3d add-on?
Dean Saadallah
12D civil engineering design standalone. The designer may have missed the variable. I'll have to experiment more and maybe contact their helpdesk.
As it's written in Australia which is metric, I would expect the defaults to be metric hence the assumption above.
At least I now know where the problem is originating from.
Thanks for your help.
I'm not familiar with it, but many symbols type add-ons have
two sets of blocks, perhaps the 'other' set is missing.
Hope you find a fix, please post back if it's an LT setting
so that we all can benefit.
Dean Saadallah
”Boost
