AutoCAD LT Forum
Hatch library location
5 REPLIES 5
marthaelena
3626 Views, 5 Replies
I'd like to add a few stone hatch pattern that I use at work and can not find the location in my laptop. I have AutoCAD LT 2012. Thank you so much.
5 REPLIES 5
in reply to: marthaelena
This is where it is for LT2010
C:\Program Files\AutoCAD LT 2010\UserDataCache\Support\acadlt.pat
also see http://forums.autodesk.com/t5/AutoCAD-LT/Importing-Hatches/m-p/2552416
Hope this helps
marthaelena
Lawson,
I could not do the same you have in yours but the link you provided helped!!!
Thank you so very much.
I have a support folder but since I did not see the other hatches there I though it could not be there but your link said that it can work and it did!
I could give you a hug!
Happy New Year
and many blessings to you.
Glad to help out
pendean
Not to steal anyone's hug away.... but that's not by default the location of the PAT file AutoCAD/LT uses unless an end user speficcally changed the destination.
For the average user it's buried under your Windows Profile (here for example in Windows 7)
C:\Users\USERNAME\appdata\roaming\autodesk\AutoCAD LT 2012\enu\support\acadlt.pat
in reply to: pendean
Dean,
When I installed LT2010 I left it up to the computer where it put it's info/program files, so that's where it ended up on a Windows 7 64bit...........
KR Lawson
”Boost
