AutoCAD LT Forum
File, Open - not working?
3 REPLIES 3
3816 Views, 3 Replies
Hi there
When I open Autocad LT I usually click on the Open button and I get a pop up block with all my files. However now when I click on Open all the buttons go grey and the only option given is in the Command box and I  have to type in where the file is - Which I usually don't know - I have to search for it.
And if I am in a drawing and I want to open another drawing I have to again enter the name of the drawing in the Command Line which is not very useful.
Everything was working fine the other and now it just does this??
Please help as this is very annoying - thank you so much.
3 REPLIES 3
pendean
You turned off FILEDIA variable most likely, look it up in HELP and explore turning it back on.
in reply to: pendean
Thank you - worked perfectly
payingtoomuch
Old topic but THANKS!
”Boost
