Hi all
I'm trying to export some DWG drawings to DGN to use them in Microstation (our customer needs the drawings in DGN files).
When I try to export the drawings, the output files are not right, in some cases the drawings are blank, sometimes there are pasts missing or the draw is modified.
Could you give me some hints about this trouble.
Thanks!
Solved by pendean. Go to Solution.
Hi rkmcswain
The drawings are so simlpe, lines, polylines, text and dimensions nothing else...
We need to deliver to the customer the drawings in DGN format as part of a project, so unfortunately it's not an option to give the drawings to the customer in DWG...
Due to this problems, now we are doing it with a trial version (opening the DWG file in Microstation and saving it as DGN). but we would like to do it simple of course.
Do you know if exists any converter?
Many thanks for your support
Hi thanks for your answers
I was "googling" about this issue, and as I see, definitely I can assume that Autocad LT is not the best option to convert a dwg to a dgn file.
I would like to try a converter (I think that is stupid to purchase a Microstation license just for conversions..)
pendean: Do you know the name of the converter from MS folks? I tried to find it but I can't.
Thanks!
Hello • i need help to covert dwg to dgn v7 • may you do it for me ? • i can [wetransfer] you my original dwg file • Thanks
