Show only
Search instead for
I am having a problem when dimensioning. When I try to dimension I get two symbols that are attached to the dimension. I dont know how they got there or how to fix them. This only happens if the arrowheads in the dimension style box is set to architectural tick. All of the other arrowheads work fine.
Yes in place of the ticks but these symbols are not even close to the dimension lines. It is just a problem in this file and doesn't happen if i start a new file.
Edited by: dcannon on Oct 30, 2008 9:52 PM
Start a new file, set up the dimension style you want, make sure the
DIMSTYLE is called the same name as the problem file's dimstyle, then INSERT
the problem file into this problem free file.
