AutoCAD LT Forum
Autocad LT2005
5 REPLIES 5
Davesnice
567 Views, 5 Replies
Autocad LT2005
How can I get LT2005 to work on Windows 7? My old computer which I need to change runs on XP professional.
5 REPLIES 5
pendean
in reply to: Davesnice
Turn off Win7's UAC and just try it.
If that does not work, explore the topic of running old software in Win7 at MIcrosoft's website and Win7's Compatibility/XP Mode.
Davesnice
in reply to: pendean
Thanks for that, I will give it a go and report back!
Did you have any luck getting info on running LT2005 on Windows 7?
I am having the same issue with needing to upgrade my old XP machine, and need to spec which version of Windows 7.  It seems there are several options:
  • 32 or 64 bit?
  • xp compatible version or non-xp compatible?
  • home or professional or ultimate?
Did you get it all set up?
Thanks...
Davesnice
Sorry but I can't help you. I eventually bought a new computer with an XP operating system as it was easier all round! Needless to say ACAD LT2005 is running smoothly on it. All the best.
Charles_Shade
  • If Win 7 you should buy 64 bit.
  1. - Problem is; will you be able to install a 32 bit LT 2005 program? Not sure but believe no
  2. - 32 bit will be inefficient if you decide to upgrade to LT 2011
  • Ultimate and Professional both have XP mode which will allow your old program to run.
”Boost
