Started new job with company using AutoCAD 2019. Doesn't seem to be a Visual styles manager. The 2017 version has it. Is there a new command in 2019?
Solved by Alfred.NESWADBA. Go to Solution.
Visual styles exist in full AutoCAD, not in AutoCAD LT as LT is not designed to work 3D.
You might play with systemvariable SHADEMODE.
The full version of AutoCAD ... yes, but not the LT version.
- alfred -
I just wanted to say thank you for this solution!
I've been trawling the internet trying to work out why WIPEOUT wasn't working in model space but was in paper space.
Other threads suggested adjusting the 2D wireframe setting but didn't explain where to find this in AutoCAD LT so thank you!
