AutoCAD LT Forum
AREA = Adding the sum multiple areas in autocad light MARCH 11TH 2011
15 REPLIES 15
Message 1 of 16
54426 Views, 15 Replies
Hi all I have a question I hope someone can help me with, I am a new user to autocad lt
I have a .dwg file that has 488 closed objects  I need to know the total sum of the area for all closed objects
I don't really want to have to use the line function for every single object to get each individual area then add them all together on a calculator.
I was hoping there would be a quicker method for this i need to know the total area of all 488 objects added together.
any help would be appreciated
Thanks in advance Smiley Happy
Jordan
15 REPLIES 15
Message 2 of 16
pendean
AREA command has an ADD function, use it's OBJECT option to select each closed area for a total.
It will highlight each one you pick as you go along.
Message 3 of 16
Use JOIN command to connect segments into polylines
Use REGION command on all connected polylines of interest
Use MASSPROP command on all regions of interest
Works better than the AREA - ADD - OBJECT method becasue with the above, you can use a window to select
Tags (1)
Message 4 of 16
Dear...
your question is to calculate all objectes area in one Command......
its very simple......if you have multiple objects and you get sum area (means Total Area) of all objects, then the method is that you can use command
"AreaM"
Before applying the commond of AreaM First you can do some simple steps
1. You have one file of AreaM (I WILL SEND YOU THIS FILE and GIVE ME YOUR EMAIL ADDRESS)
2. if you have Autocade 2015 version you will go "Manage" title bar of autocad
3.Click Load application icon
4. Load AreaM File and close the box
5. finally you can apply this command on you own purpose
Note: Every new Cadfile you want to get Value of area, first you will upload AreaM file.
I attached AreaM File in this post....
thanks
Message 5 of 16
pendean
There is no LISP ability in LT: the forum you are posting in. Nice lisp, but pointless as a fix for LT users.
Message 6 of 16
Dear Sir,
How to add areas in one command??
Message 7 of 16
hwalker
At the command line type AREA
Now press A (ADD)
Now press O (OBJECT).
You can carry on adding as many objects as you want, you will notice at the command line the total area of your objects
Howard Walker
Left Handed and Proud
Message 8 of 16
steven-g
in reply to: hwalker
so long as they are separate objects, you could hatch the whole lot, then select only the hatches with quick select or from the properties palette, this will give you the cumulative area (but it does subtract overlapping hatches)
Message 9 of 16
Emmsleys
Following up on your thread, were you able to find a solution?
Did any of the posts in the thread help with you issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select
Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 10 of 16
75094664
thanks
good one
@Anonymous wrote:
Dear...
"AreaM"
thanks
Message 11 of 16
jfirrantello
Thank you for the elegant answer. Simple, straightforward, and no LISP for AutoCAD LT users like myself.
Message 12 of 16
@Anonymous wrote:
Dear...
"AreaM"
thanks
Is there a way to have the Total be divided by 144?
Message 13 of 16
pendean
Are you running LT or full AutoCAD?
Message 14 of 16
in reply to: pendean
I am using full autocad 2018 and
Message 15 of 16
steven-g
At the command line type "MODEMACRO" and then enter this exactly as shown followed by enter
"area= "$(/,$(getvar,area),144)
then when you use the area command as shown in the comments above the results will be divided by 144 and shown on your status bar just below the command line
EDIT
for LT anyway, and it only works in the current session.
Message 16 of 16
pendean
Here is the AREAM lisp discussed above that you answered
http://jtbworld.com/autocad-aream-lsp
Change the code (I've not tested it BTW)
(getvar "area")
to
(/ (getvar "area") 144.0)
Don't omit or add anything else.
”Boost
