AutoCAD LT Forum
Archstyle.shx font style
34 REPLIES 34
Message 1 of 35
JamesPowell7164
6488 Views, 34 Replies
I have recently been asked by a new client of mine to adhere to his company's standard drawing sheet and use Archstyle.shx as the font style. Problem is I cannot find it anywhere. Any ideas???
34 REPLIES 34
Message 2 of 35
in reply to: JamesPowell7164
Ask the client to provide you will all the client's
standards requirements: don't you think?
Otherwise, browse the web, find many fonts with this name,
hope it is the one and you don't tick off the client if it
is not.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 3 of 35
This particular client does not use a computer, thus he has asked me to produce this setof drawings for him.
I have looked at the web but had no luck in locating the desired SHX file. Frustrating or what.
Message 4 of 35
James,
This is one of the greatest mysteries of the world!
The Author did a brilliant job of creating this font and then by some
fickle finger of fate disappeared off the face of the planet.
Regards Gary
www.drcauto..com
P.S. possibly a divorce!
It is still out there if you look hard enough!
wrote in message news:4994090@discussion.autodesk.com...
Message 5 of 35
jholt
Look here
http://204.101.252.14/library/fonts.html
Find several architectural fonts and ask your client if any of them are acceptable. Then use it.
I used to have archstyle.shx but can not find it in my archives. Must have been a long time ago.
jeff <><
Message 6 of 35
Mark Crowley is still around and we've talked about updating
his work to Unicode, but I haven't had the time.
I think you need to search for archstyl.shx, not Archstyle.shx.
David William Edwards
SHXConvert - Replace SHX fonts in a DWG with component objects/Blocks
Compile/Decompile SHX fonts without AutoCAD
Announcing "PROJECT NEWPLEX - THE NEW STANDARD"
FONTasm! - Truetype to Filled SHX Font/DXF File Converter
CAD Font Services - Creation, Conversion, Customization
http://www.tcfonts.com
Message 7 of 35
http://www.google.com/search?ie=UTF-8&oe=UTF-8&q=archstyl%2Eshx
Dean Saadallah
Message 8 of 35
Thank you very much for your help. I was searching with too many parameters as you suggest - one too many "e"s.
Message 9 of 35
hpa.aia.architect
in reply to: jholt
I have the font file, I loaded it into Auto-CADD LT 2021 but it does not show up correctly.  Any ideas.
Message 10 of 35
What doesn't show up correctly, we cannot see your screen, can you post a screen-shot so we can see the problem?
Message 11 of 35
pendean
in reply to: hpa.aia.architect
... and where did you 'load it" exactly?
Message 12 of 35
hpa.aia.architect
in reply to: pendean
I loaded the file in the FONTS sub-directory in Autodaek directory
Message 13 of 35
[image: image.png]
The text in the box is supposed to be Archstyle
Message 14 of 35
RobDraw
No image. An image attached to an email response will not show here.
Did you install the font or just put the file in the folder?
Rob
Message 15 of 35
hpa.aia.architect
in reply to: RobDraw
 yes I installed the font
Message 16 of 35
pendean
Is this an SHX or TTF font file?
Did you remember to restart AutoCAD/LT?
Message 17 of 35
hpa.aia.architect
it is an SHX file
Message 18 of 35
hpa.aia.architect
It is an SHX file.
AND yes I went out of the program, even turned computer off and came back next day and every day since
Message 19 of 35
RobDraw
We still don't know what is not showing up correctly.
Rob
Message 20 of 35
hpa.aia.architect
Please see the attached word doc.
All the text in the Two boxes, Code Compliance Notes and Legend is supposed to be Archstyle
”Boost
