AutoCAD Land Desktop (Read Only)
String number 25900 error
1 REPLY 1
2619 Views, 1 Reply
We are having trouble in Land Desktop 2009. This is only happening in the layout tabs, not model space. When switching from model space to paper space or vise-versa we get this error. We also get this error when zooming and panning in model space in the layout tabs.
The error window says : "Cannot find the resource string number 25900 in resource AecDisplayPropsData50" with an OK button to hit and then you go on.
It is not inhibiting us from getting work done bet terribly annoying and time consuming after a while. Please, please help!!!!
Thanks in advance>
nwonnell
1 REPLY 1
machadt
This caused for a corruption on your user profile, if you recreate your profile or repair your installations you should be set.
Tatiana Machado
AEC-ENI Application Engineer
