AutoCAD Land Desktop (Read Only)
369 Views, 4 Replies
PLINE corners
I'm using LDD 2004 - Can someone plz remind me of the command to modify how a PLINE displays each line when it comes to an intersection. I've opened an old dwg and in this dwg the pline intersections are not fillet-ed (?) to be a solid continual line, instead one line is cut off square and the other is cut off diagonally, and since the pline width is 3', the diagonal edge extends WAY beyond where I want it.
THX
4 REPLIES 4
try: Pedit, Ltype gen, on.
see attached:
do you mean you want it to look like the upper one, NOT the lower one?
if so, i believe the answer is to add/edit vertices to get the look you
want. It might have been a setting once, but probably no longer. hopefully
someone will correct me if im wrong.
wrote in message news:5423352@discussion.autodesk.com...
THX
Hmmm... if I use straight lines with the pline, it does what I want, but if I go from a line to an arc, then I get the weird corner. I added a pic to help explain... I want the intersection on the right to be like the one on the left.
yeah, I think you are stuck with that. I usually just break the pline there
to get rid of it. if it has to stay intact, an extra vertice or two in the
general vicinity might work.
if there is a setting/sysvar to get rid of that, it is very well hidden.
wrote in message news:5423412@discussion.autodesk.com...
the left.
