How does everyone make xrefs? I'm curious as to how to speed up the process.
Solved by VinodBalasubramanian. Go to Solution.
Typically, you use an xref to display the geometry of a common base drawing in the current AutoCAD drawing without expanding its size. This allows changes to the reference drawing to be reflected in any host AutoCAD drawings that refer to it.
More info on Xref command can be found here,
Here is also a good youtube video on attaching xrefs,
https://www.youtube.com/watch?v=j8s0NsYWSWs
Hope it helps. Let me know, if you have any specific requirements.
And dont forget with xrefss
just thought Id offer.
