I am jumping from AutoCAD 2011 to 2014.
and in AutoCAD 2011 i have alot of shortcuts added in acad.pgp,
and where it was easy to add by just going in the menu, adding the shortcuts in acad.pgp, executing the command "reinit", and i could use them.
In AutoCAD 2014, can't find the menu.
I even found at least 3 different acad.pgp in the directory... added them manualy...
no succes!
help...
Thanks in advance!
Sophie
Solved by Alfred.NESWADBA. Go to Solution.
It's moved from Express-tools to a standard AutoCAD menu item, with 3 options, besides of ACAD.PGP you have two more files acting similar to ACAD.PGP (similar, but not equal):
And you have also the chance to let AutoCAD find what ACAD.PGP it's using by typing in that LISP into the command line
(findfile "ACAD.PGP")
- alfred -
Thanks alot Alfred.
I know your solution will work, so as soon is I get to work I try it.
Thanks so mush!
Sophie
But where does it reside in the computer's directory structure? The findfile command isn't working in AutoCAD 2014 for me.
what do you get as result when typing in the lisp-command?
By default it's here:
C:\Users\<yourLogin>\appdata\roaming\autodesk\autocad 2014\r19.1\<yourLanguageCode>\support\acad.pgp
- alfred -
You can always do a search from Windows Explorer. Set your current folder to the root of drive C: and type the filename in the Search field.
That is what FINDFILE does - tells you where the file (that AutoCAD is reading) is located
If it returns nil, then there isn't one in the support file search path, meaning it's been deleted, renamed, or your SFSP has been altered.
Here's where I just do not understand why they make this so stupidly complicated. I can find the .pgp file. I can also do the menu Manage>Edit Aliases. My problem is that taking both those paths, F = FILLET in the .pgp file. When I type F<CR> however, I get FILETAB. What the hell is FILETAB? It's not in the alias list at all! What good is an alias list if it's NOT FOLLOWED by the screwed up latest so-called "improvement"?!?
the PGP file will define the last F character as the command, so according to your description, you have another F in the pgp file that is defined as something else (filetab?) Make sure your pgp file does not have anothe F, *FILETAB listing in it AFTER your F, *FILLET.
Since, apparently, you don't need or want FILETAB, just comment it out or remove it from your pgp file.
HTH
DJ
This is sounding more like Autocomplete is jumping the gun. Useful tool, just requires a little tweaking to accomodate individual typing speeds.
@Anonymous wrote:That's it. It's Autocomplete. The new "feature" I didn't ask for. Thank you.
If you actually want to make a difference in future releases of the software (rather than just complaining about what you don't want), sign up for beta testing.
Rather than type something at the command line just go to the Manage tab on the ribbon, look in the customization panel, edit aliases, use the drop down and pick the one you want to edit.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
"C:\Users\<yourLogin>\appdata\roaming\autodesk\autocad 2014\r19.1\<yourLanguageCode>\support\acad.pgp
- alfred -"
I found the acad.pgp file where Alfred mentions but
I found the one AutoCAD is actually using here:
C:\Program Files\Autodesk\AutoCAD 2014\support\acad.pgp
and this is the one that my 'Express Tools >Command Aliases' edits.
Per this link: https://forums.autodesk.com/t5/autocad-architecture/aca-2012-2015-pgp-file/td-p/5168015, AutoCAD uses the first acad.pgp file it finds.
Sorry for adding to an old thread, but my own troubleshooting brought me here and I think others will benefit from what I found.
to verify which ACAD.PGP AutoCAD is using you can run the lisp command
and the path which is returned as the result points you to the pgp that is used.
- alfred -
....to verify which ACAD.PGP AutoCAD is using you can run the lisp command
Looks a lot like post 2.
Also you can do this to simply open the file for editing:
(startapp "notepad" (findfile "acad.pgp"))
