AutoCAD Forum
unusual Shape to be drawn in solids
18 REPLIES 18
Message 1 of 19
618 Views, 18 Replies
Can anyone help me?
  I am working on a project (using autocad 2011)  that has a building with a two way sloping roof. What i am trying to do is draw a shape in 'solids' that replecates the shape of this building.
 Is it possible to create a six faced shape with 4 different vertical co-ordinates. a flat bottom, 4 different shaped sides, and with top face sloping from east to west, and north to south?
Cheers
Brian.
18 REPLIES 18
Message 2 of 19
dmfrazier
A picture is worth a thousand words.
Message 3 of 19
in reply to: dmfrazier
This photo should indicate the concept.
Thanks in advance
Brian
Message 4 of 19
dmfrazier
I'm no 3D expert, but while you wait for one to chime in, it seems to me this is just a "box" (elongated, rectangular), with its corners pushed and pulled a bit to get the right dimensions along the edges.  Start there (box), and start grip-editing.
Message 5 of 19
Patchy
Like this? Loft them to 3D
Message 6 of 19
in reply to: Patchy
HOW THE HELL DID YOU DO THIS?
Brian
Message 7 of 19
JDMather
in reply to: Patchy
...or this.
Loft surface line-to-line
Extrude base
Slice with surface.
Message 8 of 19
Patchy
Draw 2 triangles using 3DPOLY command, LOFT, and then UNION
Or draw them like JD's way, then SLICE it with 3 points.
Message 9 of 19
nestly2
... or SLICE if the "top" surface is planar...
Message 10 of 19
dmfrazier
in reply to: nestly2
Slice. That's the part I was having trouble with.  Nice demo.
Message 11 of 19
nestly2
Here's a couple more methods already suggested
Message 12 of 19
dmfrazier
In that 2nd demo, what did you do to the box (or to settings) that allowed the four "top" corners to be grip-edited independently?
Message 13 of 19
nestly2
CTRL + Click on a Vertex, Edge, or Face of any solid or surface to activate SubObject Selection.
Message 14 of 19
dmfrazier
Yes, I am able to get the corners to "light up", but when I move one corner down, the adjacent top corner moves with it, even though I have not selected it.  So I can only make the "roof" slope in one direction.  Also, I do not see a line appear on the top surface going from one top corner to the corner diagonally opposite, as your demo shows.  It's as if your "box" has extra "edges" or vertices.
Message 15 of 19
nestly2
Make sure you're clicking right on the corner (vertex)... it sounds like you're selecting a edge, which will light up (and move) all the red dots at the same time.
Message 16 of 19
dmfrazier
Actually, there's a little options menu that flies out when I select the vertex.  I had to click "Allow Triangulation" for it to work as your demo showed.
(Demos are great and can make things look so easy, but often the keys are in the underlying settings and options.)
Thanks for the additional tips.
Message 17 of 19
nestly2
My mistake  Although I have '12, '13, & '14 installed,  2011 is my preferred version, which doesn't have that extra menu.  I didn't know it was even there.  Smiley Embarassed
Message 18 of 19
i'm gonna sound pretty dim here but i can only draw my poly lines on the x and y axiis whist following the instructions on demo 2?
Do i need to adjust my viewport settings in some way to be able to use the z axis?.
Im just working  in a sw viewport and i suspect i need to something more drastic  to make this possible.
Thanks for your patience everyone.
Brian
Message 19 of 19
nestly2
That's the age old dilema of UCS vs View in a 3D environment.  To draw your shape using polylines / Loft as shown in the animation, you have to draw the "left" and "right" sides, so you have to change the UCS to either "Left" or "Right". (PLines can only be drawn in the X/Y axis).    Remember that the Viewport controls in the canvas and the Ribbon will change the UCS and the "view"  (Top/Bottom/Left/Right/Front/Back) while the Viewcube changes the "view" without changing the UCS
I recommend finding some reading material / tutorials on managing the UCS in AutoCAD.
”Boost
