G'day all
Here is an easyone for some free internet points (no pun intended)
hope someone has an answer.
if i get the mass properties of a solid, i get the centroid in x, y and z.
how can i make a point for these coordinates without copy and pasting the coordinates to a text file then making a point and copying the coordinates back into that point?
is there a command say CENTROID or similar where you click the 3d solid and bam, there is your centroid.
this would help immensely for crane lift plans
cheers
Marcus
Solved by vladimir_michl. Go to Solution.
Hi, Marcus,
This is not my subject of work, but it was interesting whether I would find the right thing or not.😀
Maybe something like this is from dwg.ru of kpblc - https://forum.dwg.ru/showpost.php?p=398952&postcount=20.
Second lisp - set-center-3d-m.
Centroids are blocks for each of the specified 3DSOLID or REGION.
Didn 't check!!!
For some reason in blocks of 3 points...
You can use the CENTROID "command" (an add-on with command) to draw a COG point - see:
https://www.cadforum.cz/cadforum_en/how-to-draw-a-center-of-gravity-point-tip6820
For some types of 3D objects you can also use the 3D osnap "Center of face".
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
I specifically chose set-center-3d-m.lsp because it creates points for all selected objects at once.
And specifically chose the option when points are created in blocks. Blocks can be given attributes to store and display the desired data.
And 3 points in these kpblc_dwgru_CenterPoint3D blocks were made specially - that them better it was visible in 3D. If PDMODE > 0, such "points" are always visible at any slope-turn in the 3D.
