AutoCAD Forum
My AutoCAD2009 can not start "Another program is currently using the file"
14 REPLIES 14
Message 1 of 15
966 Views, 14 Replies
Hi Autodesk team
           My AutoCAD2009 has some problem. The problem is AutoCAD2009 will be turn off automatically when we double click on start icon. And it will appear aleart message "Another program is currently using the file" as capture photo attached file.
I don't know if we remove program and then reinstall , it will be OK or not (I afraid that the request code will be changed as previously)
Could you please give me the solution to fix this problem??
Thank you in advance for the answer.
14 REPLIES 14
Message 2 of 15
pendean
Is this a new problem on an existing PC that used to work just fine? Then use Windows System Restore and go back a month or two when it all worked.
Message 3 of 15
in reply to: pendean
Pendean
            Thank you very much for reply.
This is the new problem on existing PC and I can't restore as your solution due to that PC didn't set automatic backup.
Could you please let me know the exact problem and also other solution??
Your help will be much appreciate.
Message 4 of 15
Alfred.NESWADBA
just to make sure: you have tried to restart your workstation?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 5 of 15
in reply to: Alfred.NESWADBA
Hi Alfred
           Thanks for reply.
We try to restart many time but the result still be here.
Could you please let me know the exact problem and solution?
As I ask as above "Can I remove and reinstall AutoCAD2009??" I ask you because I afraid that the request code will be changed as previously.
Message 6 of 15
Alfred.NESWADBA
The exact problem is known to you, you see it.
If anyone would know the "exact solution" I'm sure we would have told you that. But at least I have not seen that type of issue yet. So we can do suggestions/ask questions to come more close and hopefully find then the source of the problem.
In the background in your screenshot there is another messagebox with a C++ Runtime Error, have you tried to install the C++ Runtime Libraries newly?
Does the same error occur if you login to your system with another user-account (having admin rights)?
Can you then tell us what you have installed since AutoCAD run well last time?
- alfred -
Alfred NESWADBA
Message 7 of 15
Hi, Alfred
           Thanks for reply.
 >>> Now,I was install visual c++ already. The result is when I start autocad, the messagebox is disappear but
 It seem like nothing run. I try to see in task manager on processes tab it has "acad.exe" appear and on applications tab
 is not anything run.
>>> Sorry, I don't know because I'm not end user.
Message 8 of 15
Could you please see my video file following my link ? and then you will understand what we try to explain to you.
http://www.mediafire.com/download/j81yzm60z7du75s/Untitled_5.flv
Does It have to format harddisk ?
Message 9 of 15
pendean
Create a new Windows Profile with your admin rights, and test 2009: does the problem go away?
Message 10 of 15
Hi, Pendean
 I was create a new  Windows Profile : Administrator and test autocad 2009 already.
 But the problem still be existed.
Message 11 of 15
Alfred.NESWADBA
I don't know why I have not mentioned it yet: can you run a repair-install with AutoCAD? (as administrator, disabled antivirus-software).
- alfred -
Alfred NESWADBA
Message 12 of 15
Hello -Alfred-
            I try to repair/reinstall AutoCAD2009 in admin account with out anti virus running but the problem still be existed.
Do we need to format this problem PC ??
Message 13 of 15
Alfred.NESWADBA
Did you do a >>>clean uninstall<<< before starting the new installation?
As the first problem was a C++ library it might help to reinstall all beginning with the OS, but I guess nobody can guarantee that this will help, because something killed the C++ libs and maybe other files too, so that might happen again if you run the same installations again.
Good luck, - alfred -
Alfred NESWADBA
Message 14 of 15
Hi -alfred-
              Thanks for prompt response.
We follow the Autodesk instruction as this link :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Is it clean enough ?? Please help to advise the other solution or should we format the harddisk ??
Message 15 of 15
Alfred.NESWADBA
your link is the same as mine, so yes, it's "clean enough".
It's not really necessary as long as you start with installation of the OS into a different partition.
Even better: I would spent a new harddisk so in case of troubles you can restart from the old harddisk to look about files/settings/... you need from the old system..
- alfred -
Alfred NESWADBA
”Boost
