I have bunch of single line text columns that I need to convert into mtext with specific line space distance. Can I do it with ST (text style) or I need a code? Anyone???
Solved by pendean. Go to Solution.
Dean,
I am working on ic diagram converted from visio. And yes, I am using t2mtxt, but I need to apply a text style (if feasible) with specific line distance after it converted into mtxt. I have all my text on a single layer and want to move it to the diagram template with specific line distance to save my time. Your tip on removing formating was good, which I found earlier, thank you! Any time saving tips? I have around 15 drawings and not much time.
sure I can: one mtext entity at a time, I want to change ALL of them at once though, I think I need a code or record a macro and apply to all selected. Anyone???
Make your example simpler (without those lines....) because I can't understand what it would like as after it's done.
