How can I keep layer state settings locked on an xref'd model? Every time I save the original model and reload the xref, the layer state reverts back to the base model instead of keeping the applied layer state. Thanks!
Solved by chriscowgill7373. Go to Solution.
Have you verified that the variable VISRETAIN is set to 1? This typically would control this.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Set system variable VISRETAIN to "1". That should solve your problem.
