AutoCAD Forum
Issue with MLEADER objects on different elevations
2 REPLIES 2
rpeng
2258 Views, 2 Replies
I have some drawings with MLEADER objects on different various elevations, so when you print the drawing out the text is thicker than the MLEADER objects that is on elevation "0".
Since mleader object have no physical x.y.z when you look at them in the properties box, how does one go about moving them down to elevation "0"?
The flatten object found under express tools explodes them in to lines and mtext, so it is not an option.
Ray
2 REPLIES 2
jggerth
in reply to: rpeng
use point filters.  Select the mleader, and execute the MOVE command.  Select the end of the leader as the base point of the moe, and for the second point, type in .xy, select the same end point, and when prompted of the Z: value, key in 0.
Use OSNAPS (ENDPoint) for the point selection..
rpeng
in reply to: jggerth
Thank you for the suggestion, the amount of MLEADER objects that is out of place it will be probably just as quick to retype them than it is to move them one at a time 😄
However upon further investigation turns out it is an issue with the printer drive that is cause the text to be printed out thicker when the MLEADER object is on a higher elevation.
Ray
Autodesk Customer Advisory Groups
