Hello! I need some help with the revolve function in AutoCAD. So basically I need to turn this drawing:
Into something just like this (the bottom right model):
However, after setting the start/end points (0,0 / 0,10) and defining the axis & the angle of revolution (360 degrees) the 3D model keeps disappearing and I'm having trouble finding out why. Any help will be highly appreciated, thanks! 🙂
I will also attach the .DWG file down below.
Solved by dbroad. Go to Solution.
Your current layer is off. Turn it on and you will see the results.
I thought I already made a separate layer (that was active) for the model but it turns out I was on a different layer. Thank you so much!
