AutoCAD Forum
Hows to turn out the noise when you select something on a dialog?
16 REPLIES 16
Message 1 of 17
octavio2
5461 Views, 16 Replies
Can you advise on how to turn the loud bang when you click a buttom in a dialog like the Layer State and the noise comes...(V 2015)
Thanks.
16 REPLIES 16
Message 2 of 17
nrz13
in reply to: octavio2
In Windows, try going to Control Panel → Sound → "Sounds" tab → setting Sound Scheme to "No Sounds" and hit "OK" and see if that resolves the problem for you.  It sounds like someone is playing a prank on you.  As far as I know, AutoCAD 2015 does not have any sounds in the program itself.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 3 of 17
in reply to: nrz13
Sounds will be the next fantastic feature in AutoCAD! And there will be a dozen system variables to control (or not) how and when they work. I can't wait!
Message 4 of 17
nrz13
And you know it will be the next big feature because no one asked for it!  System variables?  No way!  It will be set up so you won't be able to turn the sounds off!  Smiley LOL
Message 5 of 17
pendean
Message 6 of 17
nrz13
in reply to: pendean
I stand corrected.  I had completely forgotten about that option.
Message 7 of 17
anythingcad
I'm trying to turn off the noises it makes even when there isn't an error 😕
Message 8 of 17
That is not an option in AutoCAD, this has to be set within your sound control.
Right-click onto the sound-symbol on the right side of the Windows task bar to get the sound mixing control shown (hope that is understandable as this is my translation from Gerrman) ... and there you can control the volume for the system sound.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 9 of 17
gilc01
in reply to: Alfred.NESWADBA
Thanks!!!!! 😀 You save me to be mad
Message 10 of 17
jennifer2F8PG
😆true!
Message 11 of 17
RobDraw
in reply to: jennifer2F8PG
@jennifer2F8PG wrote:
😆true!
Not really.
Rob
Message 12 of 17
dtarantino5K674
Rub it in, even CAD can shut the sound off... but no not REVIT!
Message 13 of 17
pendean
in reply to: dtarantino5K674
Message 14 of 17
dtarantino5K674
it only works for some of the complaining Revit does. the only way I have found to shut down all the noise it makes is through the PC's system sounds.
Message 15 of 17
RSomppi
Why are you complaining about Revit in the AutoCAD forum?
Message 16 of 17
anythingcad
in reply to: RSomppi
What does it matter? He's replying to someone else in a conversation, not you.
Message 17 of 17
RSomppi
in reply to: anythingcad
Brilliant!
You might want to look at what you wrote and think about who I was responding to you.
Hint:
It wasn't you.
”Boost
