AUTOCAD 2010
All my dimensions are non-associative.
I tried to make them associative by using File - options - user preferences - make dimensions asociative.
It worked but I then lost the 1 : 20 scale applied in the dimension style.
I went back in the to dimension style and made sure the 1 to 20 scale applied.
But still when I add a dimension it multiplies up by 20 times.
Does anyone know how to make dimensions associative with messing up the scale.
Can you post the drawing. A 1:20 dim style will always be 20x what your line length actually is.
Howard Walker
I wish I could but its confidential but I will try and post an extract on Monday.
Bassically its a dimension of 2000.
The viewport is at 1 to 20 do the dimension style is at 1 to 20 so comes in right.
But when I make it associative Autocad ignores my dimension style set at 1:20 and it comes in at 40000.
Thanks for your help.
Yeah that will happen. If you want your dim to stay associated you have to change the factor to 1:1
Howard Walker
