AutoCAD Forum
How can I do dwg repair file?
4 REPLIES 4
417 Views, 4 Replies
.dwg file were corrupted of unexpected switch off my PC. I used to restore my autocad file by next commands RECOVER, RECOVERALL, AUDIT. These commands didn't give any result.
4 REPLIES 4
Patchy
Do you have .BAK file of that drawing? rename to .dwg and open it.
jggerth
in reply to: Patchy
then, go out and buy a UPS so power gremlins won't cost you a drawing file.
If none of the in-Acad options will work, ty using one of the other available CAD packages and see if they can open the borked drawing, or find anything valid in it.
dmfrazier
A remote possibility: try inserting the "borked" DWG into a new, blank DWG.  If it works, Saveas (and breathe a sigh of relief).
pendean
Do you have off-your-PC backups from the day before you can access?
or a BAK file as noted above?
or an autosave SV$ in your Windows' profile Temp folder that you can rename?
”Boost
