Is it possible to bind a Geolocation Image so it's embedded in the AutoCAD file itself? For example, when offline, we need to the AutoCAD file to open and still show arial image that would normally be loaded normally via Geolocation function when online.
Solved by Valentin-WSP. Go to Solution.
You can try this as an alternative.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
