I have a model tab and two layout tabs.
All my lines have been drawn in the model tab and are flat.
When in the model tab alll the lines are vertical and horizontal and that checks out when I check the X an y positions.
But suddenly when I look at the screen it now appears slighly rotated about 1-2 degrees to my screen.
Somehow how I have managed to rotate the whole drg slightly and I want to get it back to square.
Does anyone know how to do that ?
Things could be skewed by more than one command [primarily UCS or Dview]. Most such distortions should be fixed by:
UCS command, World option
PLAN command
If that doesn't do it, you may have rotated everything, but that wouldn't jibe with your description about checking for horizontality/verticality, unless things were drawn and you checked them, in a non-World UCS, but now you're in a different one or back in the WCS. So a sample drawing with the problem would be helpful. If security forbids posting a complete drawing, can you just WBLOCK out relevant portions into a generic example drawing, without any sensitive information, and post that?
