Hello everybody,
I've installed a plugin called "BIM Track". I need this for Revit and Navisworks for searching, and solve, clashes.
But if I open AutoCAD 2018.1.2, this plugin opens also.
Because I'm using AutoCAD only for 2D drawings and AutoCAD doesn't to be linked with a Revit/ Navisworks project, I don't need to use this plugin in AutoCAD.
How can I disable this plugin for AutoCAD only? I don't see this plugin at the loaded applications.
there exists a lot of different techniques for how to implement a plugin for AutoCAD.
I would suggest you ask the vendor of that plugin for how to disable it in AutoCAD.
If we would now start with suggestions we might block other things you may have installed, so a bit risky to do that.
- alfred -
