AutoCAD Forum
Desktop Resolution Problem
3 REPLIES 3
536 Views, 3 Replies
I  Instaled AutoCAD 2012 on my Mac with a Windows parallel desktop and because of the resolution of my retina display, the software is double sized. Is there a way to adjust the size ?
3 REPLIES 3
Charles_Shade
Welcome to the Autodesk Forums!
Double Size? I assume that your Icons are huge compared to what you expect?
That is going to be Video Card settings on your Mac. I expect that you will need to change resolutions until you find one that meets your needs.
pendean
I found the solution in your forum. The problem was in the Parallel Desktop video setting. Now the resolution is ulgy compared to my Retina display put every thing got the good size. Smiley Tongue
”Boost
