AutoCAD Forum
Data Extraction Wizard does not open. AutoCAD 2014
8 REPLIES 8
Message 1 of 9
870 Views, 8 Replies
This function was working but now when the user enters the Data Extraction commad nothing happens. The wizard does not open.
Has anyone see this before?
Thank you,
Mike
8 REPLIES 8
Message 2 of 9
You have to save dwg file before entering command. Or you can use insert table->data extraction(command: Tb)
Message 3 of 9
this did not work.  still can't open data extraction wizard.
Message 4 of 9
kasperwuyts
Can you post a copy of everything that happens in your command line when typing DATAEXTRACTION?
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
Message 5 of 9
in reply to: kasperwuyts
sure.  nothing happens.  no error message.  no wizard.  it just lays there like i never entered the command.
Message 6 of 9
M_Hensley
Do your crosshairs disappear until you hit esc? If so the wizard is showing up off the screen. If not, I got no idea.
Message 7 of 9
in reply to: M_Hensley
no, but thanks for trying.
i thought about that too.  but if it was off screen, how would i find it.
Message 8 of 9
M_Hensley
If you have a dialog box off screen you can push Alt+SPACE+M then press one of the arrow keys then move your mouse and the dialog box should be attached to it.
Message 9 of 9
thanks for that info.  tried it and now i know, there is no dialog box off screen
keeping this tip, however.
”Boost
